Bt wireless modemrouter 2091 with vista
Hi, i'm using the unlocked bt 2091 modemrouter for my wireless connection. i'm thinking of upgrading to the new Vista, i need to know if this router will be compatible to Vista.
All opinions welcome
cheers
1 REPLY
If I remember correctly the Voyager 2091 has both ethernet and wireless in addition to USB, so the simple answer is "yes- as long as you're not using USB to connect to the Vista computer".
