Bluetooth
Bluetooth
Is it posable to conect to the internet from a laptop to a desktop pc using bluetooth?
Bluetooth Connections
Bluetooth is a specification allowing devices to connect wirelessly together within a small range, like mobile phones, headsets, computers, mice, keyboards, etc. At this point I don't know of a modem or router equipped with Bluetooth as it doesn't provide the range that 802.11g provides. While it wouldn't be difficult for a company to design a Bluetooth modem or router, I wouldn't hold my breath.
Bluetooth
Some of the dongles like MSI do allow a network connection from the dongle so it should in theory be straight forward but I havent tried it.
You would have to check the software/drivers thats comes with the dongle more so than the dongle its self
Bluetooth
http://www.zoom.com/products/bluetooth_overview.html
Bluetooth is a bit pointless for this kind of thing really. If you dont want wires, you may as well go proper wireless
Bluetooth
Yes, its called a PAN. Your desktop needs a LAN set up first. I have got it working with bluetooth on my iPaq.
It can be fiddly to set up but it can be done.
