Apple mac, plusnet and wireless
Hi everyone, in the process of migrating to plusnet and need some advice.
I've got a mac mini with airport card and tiger installed. I want to create a wireless network with the mac connected wirelessly to plusnet and also be able to connect my xbox via ethernet. I've looked at the NETGEAR DG834G which looks like it will provide what i need. Is this the right choice?
Any advice will be grately received - Dan
Plusnet Staff
Plusnet Staff
That router (as should pretty much any wireless router). It's one I use myself and works fine with both my Xbox and my Mac (although that's wired as I haven't got round to getting the Airport card) and PC's.
thanks for the reply.
can i connect my xbox directly to the router?
is it easy to setup?
sorry for all the questions just want to get caught out with incompatability issues
:roll:
As far as I know you are able to connect the xbox to the router.
