550 relay not permitted
cantthinkofanam
Anybody got any idea what this message means? I'm trying to use my wifi laptop on my daughter's network. Receiving emails OK, but trying to send results in an item from System Administrator (where?) saying 'Your message did not reach some or all of the intended recipients.' and the 'explanation' in my title.
I am not a techie!!
Using webmail worked OK three times out of four.
Help, please?
1 REPLY
Normally you get this error message when sending an email from a non Plusnet connection - which will not work.
I presume that your daughter is not using Plusnet as her ISP. If this is the case, then your only option is to use webmail to send email.
