www.adobe.com
- Re: www.adobe.com
www.adobe.com
27-12-2008 9:45 PM
Re: www.adobe.com
27-12-2008 9:55 PM
Re: www.adobe.com
27-12-2008 10:14 PM
Re: www.adobe.com
27-12-2008 10:20 PM
Re: www.adobe.com
27-12-2008 10:35 PM
Have you tried the IP address directly in your browser?
192.150.18.101
If the IP works your looking at a DNS issue, you may also want to try deleting history files etc.
Re: www.adobe.com
28-12-2008 5:05 AM
Adobe use a lot of it on their site - especially since they bought Macromedia
if not - get it here
http://get.adobe.com/flashplayer/?promoid=BUIGP
Re: www.adobe.com
28-12-2008 1:01 PM
Quote from: mal0z Have you got Flash installed on your PC ?
Not on this one, no.
Quote if not - get it here
"Sorry, your platform is not supported."
Makes no difference whatsoever in being able to resolve http://www.adobe.com or http://192.150.18.101
Re: www.adobe.com
28-12-2008 1:02 PM
Quote from: loungehake Attention PlusNet users: Can you open www.adobe.com in your web browser?
Works for me.
What are you using for DNS (you may want to try OpenDNS)?
Can you ping / traceroute www.adobe.com?
gruyere# mtr -rc20 www.adobe.com
HOST: gruyere Loss% Snt Last Avg Best Wrst StDev
1. home.gateway 0.0% 20 5.0 2.6 1.9 8.3 1.5
2. lo0-plusnet.pcl-ag01.plus.ne 0.0% 20 28.8 29.8 26.3 42.2 3.5
3. gi1-2-803.pcl-gw1.plus.net 0.0% 20 29.2 57.1 25.7 204.7 54.4
4. te2-2.pte-gw1.plus.net 0.0% 20 87.5 31.2 25.7 87.5 13.4
5. te2-4.pte-gw2.plus.net 0.0% 20 28.3 50.2 26.2 205.1 48.0
6. 80.239.193.141 0.0% 20 27.4 28.1 25.8 32.2 1.6
7. ldn-bb2-link.telia.net 0.0% 20 42.4 35.0 25.7 155.4 28.6
8. ldn-b5-link.telia.net 0.0% 20 26.8 27.2 24.6 29.2 1.3
9. verio-129583-ldn-b5.telia.ne 0.0% 20 28.1 35.2 26.0 169.1 31.5
10. xe-2-3-0.r22.londen03.uk.bb. 0.0% 20 29.2 30.7 27.3 53.9 5.7
11. as-0.r20.nycmny01.us.bb.gin. 0.0% 20 102.8 109.1 102.8 131.1 6.1
12. ae-0.r21.nycmny01.us.bb.gin. 0.0% 20 105.8 107.9 103.4 120.4 4.0
13. p64-2-0-0.r20.chcgil09.us.bb 0.0% 20 137.1 137.4 133.4 142.5 2.9
14. ae-0.r21.chcgil09.us.bb.gin. 0.0% 20 141.8 141.7 133.1 184.3 11.9
15. p64-7-0-3.r20.snjsca04.us.bb 0.0% 20 236.6 205.0 197.6 236.6 8.5
16. po-1.r02.snjsca04.us.bb.gin. 0.0% 20 204.2 201.0 195.9 205.6 2.5
17. te-5-3.r02.snjsca04.us.ce.gi 5.0% 20 202.3 201.0 196.1 205.9 2.7
18. 192.150.18.11 5.0% 20 201.9 200.2 196.3 207.1 2.9
19. 192.150.18.101 5.0% 20 204.9 202.6 196.1 207.7 2.8
It's worth checking which gateway you're on - if it's a routeing problem, a reboot of your router might get you a different gateway.
Re: www.adobe.com
28-12-2008 5:17 PM
BTW, I reboot my router every morning after routinely switching off last thing at night.
Re: www.adobe.com
28-12-2008 11:44 PM
Had a similar issue with my Netgear router when I migrated to PN, removing and restoring the power didn't fix it.
Can only put it down to the firmware going a bit bizarre.
Re: www.adobe.com
29-12-2008 6:35 PM
I am in the process of selecting a paper clip for the necessary factory reset operation.
Re: www.adobe.com
29-12-2008 8:16 PM
Re: www.adobe.com
04-01-2009 10:09 AM
I tried each of the following firmware versions without success: -
cfe-voyager2100-v021801_13_a023g1
cfe-voyager2100-v021801_17g_a023g1
cfe-voyager2100-v021801_17i_a023g1
I can ping without a problem.
C:\WINDOWS>ping www.adobe.com
Pinging www.wip3.adobe.com [192.150.18.101] with 32 bytes of data:
Reply from 192.150.18.101: bytes=32 time=185ms TTL=243
Reply from 192.150.18.101: bytes=32 time=188ms TTL=243
Reply from 192.150.18.101: bytes=32 time=190ms TTL=243
Reply from 192.150.18.101: bytes=32 time=183ms TTL=243
Ping statistics for 192.150.18.101:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 183ms, Maximum = 190ms, Average = 186ms
Strange eh?
All my other routers (Solwise SAR110, SAR130 and SmartAX MT882) connect without a problem.
Re: www.adobe.com
04-01-2009 10:43 AM
Re: www.adobe.com
04-01-2009 12:52 PM
I pinged www.adobe.com with the -f option and no packet fragmentation was reported.
Lord knows what peculiarities exist within the BT Voyager 2100. It's not my regular router: I possess it because the DMT utility for that particular router is very useful for diagnostics.
