wrist band
- wrist band
- « Previous
- 1
- 2
- Next »
Re: wrist band
20-10-2010 4:28 PM
Re: wrist band
20-10-2010 5:34 PM
I made sure it was unplugged from the mains.
Why do you need a sledgehammer to force memory into the teeth of the motherboard?
I didn't use any anti-static devices and I'm sure I touched all the bits that you're not meant to touch.
The PC is still working.
Re: wrist band
20-10-2010 5:38 PM
Re: wrist band
02-11-2010 6:47 PM
Quote Same applies if you're wearing clothes with static in them too
Best solution is to be naked with PC still plugged in. Gets a few raised eyebrows when the neighbours pop round, though.
I've never used anti-static straps and my wife hates me to leave it plugged in with the case open. I usually stand on a non-carpetted floor and still frequently touch the radiator.
Forum Moderator and Customer
Re: wrist band
02-11-2010 8:43 PM
Re: wrist band
03-11-2010 9:52 AM
Re: wrist band
03-11-2010 1:16 PM
Quote from: Mav I've never used anti-static straps and my wife hates me to leave it plugged in with the case open.
All the dangerous voltages are contained inside the power supply box, so as long as you don't take apart it is perfectly safe.
Re: wrist band
03-11-2010 1:52 PM
Re: wrist band
03-11-2010 1:59 PM
Re: wrist band
06-11-2010 4:35 PM
Quote from: Peter
Some reports say latex gloves can actually make static worse! Just think of when you last rubbed a balloon on a jumper and stuck it on the wall using static electricity. If it was anti-static it would not stick!
Certainly true about balloons but the last thing you need in an operating theatre would be anything that could cause a spark with all the gases (ie Oxygen, nitrous oxide etc) in the place.
When I mentioned gloves I had in mind the ones surgeons use not the Marigolds type that you might wear to do the dishes
Re: wrist band
06-11-2010 9:48 PM
Quote from: Peter Some reports say latex gloves can actually make static worse! Just think of when you last rubbed a balloon on a jumper and stuck it on the wall using static electricity. If it was anti-static it would not stick!
Yes it would - it's the balloon and woollen jumper that aren't conductive.
The conductivity of what you use to hold the balloon is immaterial - rubbing the balloon causes it to build up a charge, distributed over the balloon.
When you put it next to a wall, it induces an opposite charge on the wall.
The two opposite charges attract, making the balloon stick to the wall.
Re: wrist band
06-11-2010 11:21 PM
Modern PC power supplies do not fully switch off when you shut the computer down via the front panel buttons or via a menu function. It may look like it is off, but the PSU continues to provide stand-by power to some parts of the computers's circuitry, in order to support features like 'wake from hibernation' or 'wake on LAN'. There is no risk to personal safety (stand-by power is only 5 volts,) but there is a risk of accidental damage to the PC while working near components that are connected to stand-by power.
The only way to ensure that the PSU is turned off is to switch off the mains.
Re: wrist band
06-11-2010 11:32 PM
Quote from: Sean Yes, the power supply. You definitely do not want to work at that with the mains still attached.
Been there and done that, I can remember fault finding live switch mode power supplies. Plenty of concentration and a healthy dose of respect. Plus a colleague standing over and crash team on standby. It was worth it for the £10K that its saved.
- « Previous
- 1
- 2
- Next »
