wireless, wired, or just WEIRED...!
- wireless, wired, or just WEIRED...!
13-02-2012 11:44 PM
My laptop was switched off at the mains socket... and on the laptop power switch...
and yet... it seems... I did a couple of "My Broadband speed tests"....
Today 12:36 6932 kbps (867kB/s) 1014 kbps (127kB/s)
Today 12:15 6898 kbps (862kB/s) 977 kbps (122kB/s)
It is normally "wireless" connected too !... and normally I get around 10 to 12 megs for my speed results...
Weired or what ? ? ? ? ?
Re: wireless, wired, or just WEIRED...!
13-02-2012 11:50 PM
14-02-2012 8:25 AM
14-02-2012 8:48 AM
14-02-2012 8:59 AM
shortcut to " Windows PowerShell Modules "
Using Windows Vista Home Premium
14-02-2012 9:11 AM
14-02-2012 9:58 AM
14-02-2012 10:03 AM
If you run a new speed test yourself does it still show the spurious results?
14-02-2012 11:18 AM
14-02-2012 2:53 PM
@ Gus....your < eventvwr.msc > worked... nothing showing on the event logs between 0835 and 1610 (shut down and boot up)... did not expect it too, as no-one else at home all day either !.
@ jelv.... don`t know about IP whether fixed or not.!...
@sprite.... don`t think so, as it is security keyword protected.
Just one of those "weird" things... not particularly worried about it... so thanks for the help guys..
just done a speed test
Date ........ Download Speed .......... Upload Speed
Today 14:54 12929 kbps (1.62MB/s) 363 kbps (45.4kB/s)
no other speed tests showing for today!.... ( I use ccleaner every night at shut down so previous days are lost)...
