wireless security codes
pohelia
After a fault with my laptop I'm now trying to reconnect to my wireless connection, but can't for the life of me remember my security code. Is there a way to retrieve this or reset in on my main computer?
The main computer is running XP and the laptop is running Vista (if that makes a difference to setup etc)
I've tried creating a backup from the desktop onto a USB stick to transfer the settings but with no sucess, I'm not sure if that's due to the different operating systems or just be being stupid!
1 REPLY
Re: wireless security codes
Moderators Note
Please do not spam the boards with multiply thread on the same subject.
http://community.plus.net/forum/index.php/topic,57999
Jonathan
aka Chilly
