wireless hard drive
- wireless hard drive
wireless hard drive
11-11-2013 12:01 PM
hi, I was wondering has anyone brought a wireless hard drive I asking cos I am thinking of maybe getting one and just wondering what people think of them and are they worth getting and what one maybe the best.
Thanks,
Thanks,
1 REPLY 1
Re: wireless hard drive
11-11-2013 12:28 PM
Probably easier to plug a NAS drive into your router and use it that way.
I've never used a true wireless hard drive but I suspect you'll get around half the bandwidth as both your computer and hard drive will be using the same channel.
