wireless conection
- wireless conection
wireless conection
12-12-2008 11:59 PM
can anyboby please tell me why my laptop will only stay connected to my thompson router for about a week, before i have to reset the bloody thing, router that is, can't blame laptop as it was connected to a bt home hub for last 18 months with no wireless connetion probs,only way for connection stabilaty is to connect to my neibours unsecured wireless box, but ps3 won't connect wireless as well ,have to have that wired, yes wep codes are correct.
2 REPLIES 2
Re: wireless conection
13-12-2008 9:49 PM
Do you really mean WEP? You should really be using WPA, as it is much more secure. WEP is outdated now and can be cracked in minutes.
You could try installing <a href="http://www.netstumbler.com/downloads/">Netstumbler</a>, which is a tool for diagnosing wifi issues. it could be that this router is using the same channel as your neighbour, for instance, and the two are affecting each other. Changing to a different channel might help.
Do the router's logs reveal anything? Is the disconnection happening at the same time of day, for example?
13-12-2008 11:17 PM
Do you get a decent wireless signal strength?
If you are you are using Windows, it will show the relative strengths of wireless access points near you.
Actually, I found that WPA was slightly more sensitive than WEP to weak wireless signals.
