wireless checking
Slick
wireless checking
is there any tool/program that will tell me who is downloading on a wireless network?
im the hard wired admin and have 2 other pc's connected to the network,
ive set wep security
ive set mac address filtering
so on my dchp list i only have the 3 pc's showing.
when i try an d play online games i have a terrible ping 300+
i asked the kids and they all say no,
so i want to catch them out
any ideas?
James
Re: wireless checking
Block access from their MAC Addresses? Smiley
Slick
the only way i can block them is to delete them from the list,
i have a "Belkin  F5D7633-4"
any other ideas?
or if you know a setting i can use?
Pendragon
I had a quick Google and found this page where you can download a flash tutorial for your router. It does have a bit about access blocking for an individual or range of PC’s based on protocols. Don’t know if it will help you.
Regards, P.
You can set them up to connect via a proxy if your pc is always on and that can log everything they do get a free one from
http://www.youngzsoft.net/
or get whats transferring free from
http://www.wfshome.com/software.htm
you can then sniff everything they do
Slick
il have a look thanks guys
Andy_P
Did you get any further with this Slick?
I have notice that my off peak usage was 6MB on one occasion and my PC & Laptop were both switched off at he time.  Maybe I am paranoid but I have now changed the SSID and the WPA password (the SSID never has been broadcast and MAC address filtering is on too).
