wireless channel choice
- Re: wireless channel choice
08-01-2016 7:36 PM
My wireless connection is set on Channel 1...... looking at inSSIDer, ... I can see it has 2 others on same channel.... ch 1 covers 1,2& 3 My sig level is 30 .... other two are 70 and 80 respectively
the next group of 5 stations is centered on chan 6 , so covers 4,5,6,7 & 8 these have much lower sig levels ( max is 80)
the next group of 3 stations centred on channel 11 ( all sky boxes) . covering 9,10,11,12 & 13 ( highest available channel) ( sig rating max of 60)
So, would I be better off changing to channel 6 , or opting for an overlap on either 5 or 7
those on channel 6 seem to be giving the lowest signal level, ( if I were to try and connect, I suspect they would report out of range, they are so low)...
4 REPLIES 4
08-01-2016 10:24 PM
From those figures I would suggest you try channel 6.
It is always best not to overlap channels. As when two networks are on the same channel and in range they can co-operate. Where as overlapping can cause issues without the benefits of co-operation.
If possible switch to the 5GHz `a` band. As there is much less interference. And as the signal does not travel so far fewer other networks.
09-01-2016 9:24 AM
Thanks for the reply..... will go to chan 6..... I don`t think the Tecnicolour 582n has 5Ghz...... at least, no signals are being shown on inSSIDer on 5Ghz... ! so assume it is not available.
07-07-2016 1:37 PM
Is it advisable to manually select a wireless channel other than 1, 6 or 11?
I set my router up to use channel 13, and AFAIK this hasn't been problem, but would this be detrimental compared to 1, 6 or 11?
My other car isn't a Ferrari
07-07-2016 10:16 PM
Only if you have Dell products My printer will not use channels 12 and 13.
I use channel 13 and have not noticed any (other) problems.
Phil
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
