windows wont boot correctly. stuck in a loop
- windows wont boot correctly. stuck in a loop
06-07-2009 6:53 PM
I have a pentuim 4 desktop which wont start up XP properly
The usual start up goes ok then the windows startup with the green dashes crossing the page on a black
Instead of going to the next stage it just stops and goes back to the beginning again. It would go on doing the same endlessly if I didn't cut the power.
I tried "Safe mode" without luck, tried starting with last good configuration and tried the option to not restart with a windows boot error
Nothing has worked.
Has anyone any idea of the cause and possible solutions
Nothing has worked.
2 REPLIES 2
Re: windows wont boot correctly. stuck in a loop
07-07-2009 3:59 PM
Check the motherboard, processor and HDD temps. Are the all the fans working?
Forum Moderator and Customer
08-07-2009 12:40 PM
Someting similare happened to me last year, turned out it was 1 of the sticks of RAM i had.
So i removed them 1 at a time to find out which one it was and voila!
