windows update on 12th possible Bsod cause- Edit Not a cause
- Re: windows update on 12th possible Bsod cause- Ed...
13-08-2009 4:13 PM
edit: Vista64
13-08-2009 4:33 PM
What version of Windows are you using? - If there is a problem it might not apply to all versions.
13-08-2009 5:17 PM
Also the next time I booted Kaspersky reported a suspected keylogger
which I allowed to continue as I assumed it was a false alarm
Quote 13/08/2009 09:11:08 Detected: PDM.Keylogger Absent Keylogger activity kernel mode memory patch
No problems since - also running Vista 64 bit
13-08-2009 7:53 PM
14-08-2009 9:52 AM
I'll wait a bit longer though before I let the update push out across the LAN.
14-08-2009 3:32 PM
Re: windows update on 12th possible Bsod cause- Edit Not a cause
15-08-2009 10:31 PM
15-08-2009 11:03 PM
16-08-2009 12:04 PM
17-08-2009 11:21 AM
as ReedRichards says, the BSOD error message should provide clues as to the problem.
17-08-2009 2:03 PM
