windows update..... how long ?
- windows update..... how long ?
13-08-2014 3:04 PM
it says... "Installing update 3 of 14...
security update for Microsoft.NET Framework 3.5.1 on Windows 7 SP1 x86 ( KB 2937610)
It has been showing this for about 30 minutes now, with no movement on the red progress bar....
I have clicked "stop installation" about 10 mins ago, but no progress further...
Any suggestions ?
Re: windows update..... how long ?
13-08-2014 3:08 PM
I would be tempted to go into Task Manager > Applications and kill the update application. Then re-run Windows Update if the procedure appears frozen.
13-08-2014 3:13 PM
Never known it to "stick" on one update for over 30 mins though...hence my query... If it is showing as an update still to be applied, I will uncheck it, and proceed, then probably update it as a stand alone item, .... it may "go in" better after all the other stuff has done its best !..
cheers
13-08-2014 3:17 PM
The particular update fails 1st time around but succeeds on a subsequent attempt.
13-08-2014 3:20 PM
13-08-2014 3:29 PM
13-08-2014 3:35 PM
gonna blow it to bits now.... force shut down, (hold the power key down) .... and see what happens
Re-started windows at 15:37.... showing "preparing to configure ...... " message.... Ah well.... good job I`m not wanting to use it ............yet ! ! ! ...
and now...15:38... showing "Welcome".... and showing the desktop at 15:39... .... .... .... hey ho! here we go !>>>>...
13-08-2014 3:48 PM
Now after a re-start... I have the following message...
Windows is up to date..... There are no updates available for your computer
However...underneath that it says.....
Most recent check for updates..... Today at 13:40
Updates were installed: Today at 15:06 (Failed) View Update history
As I finished typing that... got a message saying 12 updates are available showing the "offending" .NET framework update as 35.1MB and another under it as 10.5 MB.... think I will uncheck them and let the rest go first ! ...
Watch this space...
16:10 10 updates successfully downloaded and installed..... now going to see about the 2 .Net framework ones......
13-08-2014 5:21 PM
13-08-2014 5:36 PM
:-at 17:23 started to "download 2 updates ( 45.6MB in total)... am on a wifi connection ( about 2 feet from the router... and my download speed is about 4.6Mbps )
now 17.34 (11 minutes) and it is still showing as downloading 2 updates ( 0KB total, 0% complete).. and the red progress bar is running........
17:46 (23 minutes) ditto ditto ditto ditto ditto ditto ditto ....................................................................................ditto ditto ditto ditto
18:13 (50 minutes) Ditto________________________________________________________________________________Ditto
18:27 (1 hour 4 mins) ..... Now showing "installing updates" 1 of 2 ! ! !
13-08-2014 6:41 PM
14 updates , download , install , reboot = 7 mins
13-08-2014 6:49 PM
13-08-2014 7:43 PM
19:30 still showing Installing 1 of 2 but the red progress bar..... isn`t.... it ain`t there... not showing .. ....
I have even put it on Mains power...t o see if that will speed things up..( apart from my 6 hour battery life has expired ! ! ! )...
WOWZER ! ! !.... 19:55 just starting to move the "progress bar "! ! ! ! ! !
13-08-2014 8:27 PM
