windows media
- Re: windows media
windows media
02-04-2008 11:04 PM
Hello. i tuned in to w-media today to listen to james blunt on pc and was asked if wanted to upgrade. did>>> and now i can't find the icon for media or how to make one. can play my music on media but have to trace the track first before it appears. also it doesn't play the cd continuously. help would be appreciated to get a shortcut or something. thanks firefly2
2 REPLIES 2
Re: windows media
03-04-2008 9:18 AM
What icon are you talking about and where is it normally located?
Re: windows media
04-04-2008 10:16 AM
Hi okrzynska. the windows media, after upgrading disappeared from the pc . it did not show in short or long program list or installed progs . the icon was the shortcut that had previously been on the desk-top. however it must have needed a reboot as the window media is back on the list now thanks for showing interest tho' . firefly2
