windows doesn`t "see" my Caddy HDD
- windows doesn`t "see" my Caddy HDD
- « Previous
- 1
- 2
- Next »
Re: windows doesn`t "see" my Caddy HDD
13-04-2015 12:00 AM
A couple of times I tried to delete the volume, and it crashed my windows laptop.... ( Blue Screen with loads of writing on it !).. re booted and runs ok still... but am not much, if any, further forward...
13-04-2015 3:38 AM
http://www.partition-tool.com/
Works well when windows (as usual) fails...
13-04-2015 8:33 AM
13-04-2015 11:43 AM
13-04-2015 2:42 PM
@2cv hmm doesn`t "actually" do anything.... unless it is Paid For....
EaseUS Partition Master Trial Edition
The trial edition cannot execute the operation
Please enter the serial number you received to activate the product:
Serial Number : [_______________________________________]
X Please enter the valid serial number in the input field.
If you don`t have the serial number, please purchase it. Buy Now
13-04-2015 2:57 PM
I tried to "erase" the contents of the Linux hdd,.. through "Eraser 5.6" via the Windows hdd (as it now showss the drive ( F: ) and the contents on the "computer" .. however.. the erasing reports "failed" against all the files and also...........
"The media is write protected"...
don`t know how that works ( or not ) as I never made the hdd write protected..... ( wouldn`t know how to.... ! )
EDIT EDIT EDIT EDIT
Just put a Mint17 hdd in the laptop... and the "offending" linux hdd in the caddy... ( shows on the "computer" ) however cannot "open" it to reveal the contents... as Mint 17 says it is unable to mount the drive.... right clicking on it again... then "properties"... then "permissions"./// i t states
"The permissions of Hitachi xxxxxxxx could not be determined"...
13-04-2015 3:03 PM
Is the disk formatted in the GPT or MBR style?
13-04-2015 3:13 PM
Don`t know/understand "gparted"... so would need some guidance on that, please....
Don`t know whether it is GPT or MBR either ! ! .....
13-04-2015 3:33 PM
Menu > Preferences > Disks ( Manage Disks & Media ) >
Offending drive ( Hitachi ) shows as 250 gb with fee space of 250 gb ... clicked on the + sign... and it gives the option to erase the contents.. and also to change it to NTFS .. so clicked on Erase ( don`t overwrite) (quicker)... and within seconds, it shows the rive as
Filesystem
Partition 1
250GB NTFS
Now rebooted with my windows hdd in the laptop.... the offending Hitachi hdd now shows "this folder is empty".. with 232GB space...
control panel > Admisinstrative tools > Computer Management > Storage > Disk Management shows
(F:)
232.89 GB NTFS
Healthy (Primary Partition).
So ,... hopefully,.. all is now done ! ! ! ...
13-04-2015 6:37 PM
Quote from: shutter Hmm..... On the Mint 17
Aaah, Mint disk management as suggested in #12
Phil
13-04-2015 7:39 PM
something a little more clear.... like....
on a Linux Menu ...
And I would have known what you meant ! ! !
13-04-2015 8:04 PM
Quote from: shutter @2cv hmm doesn`t "actually" do anything.... unless it is Paid For....
Weird, I've been using EaseUS for a few years and it's always been free to use, I shall check that link, see what's what...
Did you download the Free version or one of the paid versions? If the latter I think they do indeed put those into trial mode so you can't actually use them, which is kind of annoying to say the least...
Bit barn door I know, but it's got me wondering now...
13-04-2015 9:54 PM
Many thanks to all for their contributions... have learnt a lot over the past few hours ...
13-04-2015 11:14 PM
Quote from: shutter ...
I would have said "Menu > settings > disks" for Mint/xfce or "Menu > System > YAST > Partitioner" for openSUSE/KDE, as that's what I use
Phil
14-04-2015 12:02 AM
- « Previous
- 1
- 2
- Next »
