windows defender
- windows defender
windows defender
21-08-2010 4:52 PM
I understand it is inadvisable to run 2 anti virus programs at the same time so if you use avast, avg or other program should windows defender be switched on or off ?
We are born into history and history is born into us.
3 REPLIES 3
Re: windows defender
21-08-2010 4:55 PM
In a word (or 2) it depends.
Defender is antispyware and I've had good results running it WITH basic antivirus products. (e.g. AVG Free 8.)
With a more comprehensive product that includes antispyware functions it's maybe superfluous and may even be turned off by the product.
Or just use Microsoft Security Essentials.
21-08-2010 4:58 PM
I have windows defender turned off
and my separate antivirus is turned on
21-08-2010 5:05 PM
I left it on and as Kaspersky doesn't object no other anti virus will either as it is notoriously picky
