windows defender
gleneagles
Aspiring Legend
Fixes: 17
windows defender
I understand it is inadvisable to run 2 anti virus programs at the same time so if you use avast, avg or other program should windows defender be switched on or off ?
We are born into history and history is born into us.
3 REPLIES 3
HPsauce
Re: windows defender
In a word (or 2) it depends.
Defender is antispyware and I've had good results running it WITH basic antivirus products. (e.g. AVG Free 8.)
With a more comprehensive product that includes antispyware functions it's maybe superfluous and may even be turned off by the product.
Or just use Microsoft Security Essentials.  Wink
magnetism2772
I have windows defender turned off
and my separate antivirus is turned on
Oldjim
Resting Legend
Fixes: 63
I left it on and as Kaspersky doesn't object no other anti virus will either as it is notoriously picky
