windows 7
morgan2476
windows 7
Just installed windows 7 It will not recognise the Thomson Router.  I have installed all the MB drivers and nothing happens.  When I type in the address for the router nothing happens.  Anybody got any ideas.
Donald
Fixes: 12
Re: windows 7
Is the Ethernet green light on the Router flashing?  It is possible that the Ethernet Port is not active (I'm presuming that you are connecting via a cable and not Wireless)
Maurice
morgan2476
Re: windows 7
Hi MauriceC.  All the lights are OK.  I am wondering if it something to do with driver that came with the MB.
morgan2476
Re: windows 7
Sorted.  I made the mistake of installing the network driver that came with the MB  I let windows 7 install its own driver and now everything is OK
