win 7 pro - admin password
- Re: win 7 pro - admin password
23-01-2015 7:47 AM
If necessary I'll reload the OS but wonder if by booting from a CD and repairing the existing OS I might get a chance to re-enter the admin password.
23-01-2015 8:03 AM
23-01-2015 9:55 AM
If you need it, there is walk through guide here :
http://pcsupport.about.com/od/toolsofthetrade/ss/ontpre-screenshot-guide.htm
Regards
Mike
24-01-2015 6:22 AM
07-09-2016 10:41 AM
Offline NT password usually works. But I'm not sure if it can cope with the complexities of a Windows 8/10 machine that uses your Microsoft account credentials to login.
08-11-2016 8:37 AM - edited 08-11-2016 8:39 AM
Seems to me that's more of an advert than a tutorial. The best way to recover a password is to write it down, together with the accompanying user ID and a note of what it is for. Use a notebook for passwords and keep that book in a safe place. Then recover the password by consulting the book! That's far less faff than creating a reset disc or USB and it works for all your passwords, not just the one that gets you into Windows.
08-11-2016 9:53 AM
Offline password reset works on Windows 10 as long as you are using a local account. You can use a local account on Windows 10 by very carefully reading the small print during setup and skipping the step when you are asked for your Microsoft account. Or after installation, by changing the account type from Control Panel.
08-11-2016 1:30 PM
Whereas if you are using a Microsoft Account on Windows 8/10 thenyou should be able to reset your Microsoft password on another device with internet access.
