win 7 disc access
- win 7 disc access
win 7 disc access
16-05-2014 5:36 PM
Re: win 7 disc access
16-05-2014 5:56 PM
Have you turned off all the graphical bells and whistles
What do you have the page file set to and what is the spare space on the C: Drive
What is the graphical resolution of the monitors
To answer the original question - yes they need more memory
A further test - start system monitor and see what happens to the memory and page file when it grinds to a halt
16-05-2014 6:30 PM
there is no graphics card in there, so I presume its running off system ram.
Aero etc is on and seems fine however I will try with them all off.
page file is system managed. Drive is an 80gb model, with probably 50 to 60gig free
graphics resolution is 1280×760 I think.
I have started task manager and memory useage is over 800meg, but cpu relatively low useage. System monitor tells me there us 100%hdd access.
16-05-2014 6:31 PM
Another thing worth checking is just which processes get activated at start up. All sorts of stuff adds a process to e.g. 'check for updates' which have to be added to the queue.
You can use MSconfig to remove the unwanted ones OR you can download and run Autoruns for a more comprehensive view of what's happening at start up. Hopefully with a bit of a tweak on Pagefile and unwanted Startup processes you can get an acceptable level of perormance pending an upgrade.
Maurice
16-05-2014 6:37 PM
I had already used msconfig to reduce startup items... as its a system for mainly internet access not much is actually installed on it.
Its got adobe reader, avast antivirus, quicktime, flashplayer, office 2007, firefox.
how would you recommend altering the pagefile. I do intend on adding an extra 2gb to each, or would 3gb be overkill?
cheers
16-05-2014 6:43 PM
16-05-2014 8:29 PM
16-05-2014 8:58 PM
Don't forget to manually check from time to time.
