win 10 privacy
rongtw
Fixes: 12
win 10 privacy
Worried about win10 phoning home ,,, i have just found this
https://www.oo-software.com/en/shutup10
chuffchuff
Re: win 10 privacy
Will you be using it?
rongtw
Fixes: 12
Re: win 10 privacy
Yup i have it ,, some settings there  that i was not aware of before Smiley
ArthurDent
Re: win 10 privacy
I'm quite neurotic about the sneaky things that MS seems to get up to, so this looks like a useful facility. Unfortunately I also find that some of the entries shown are way beyond my understanding - which is not uncommon these days. But cheers, Ron!
Fixes: 37
Re: win 10 privacy
This company reports to be a Gold MS Partner but I can't find them in the list, so maybe it's not Windows 10 you need to worry about!
Fixes: 62
Re: win 10 privacy
Fixes: 37
Re: win 10 privacy
I did search using O&O but wouldn't have thought that made much of a difference, I also checked the listing for Berlin and they weren't shown, so an excellent spot @Oldjim. Evidently I was driving it wrong.
