wifi to device slow
FIXED- Subscribe to RSS Feed
- Re: wifi to device slow
15-01-2017 2:30 PM
Been with plusnet a good while, everything has been fine speed wise. Last couple of days our phones and laptop are really slow at opening pages, checked my connection to internet, speed seems fine. reset router etc. still no joy. tg582n. I,m not the most technically minded person mind... thanks
Fixed! Go to the fix.
15-01-2017 2:56 PM
Download a wifi analyser & check to see if all your neighbours are using the same wifi channel as you, or the adjacent ones, and change you router to use a channel away from the crowd
Most routers have an auto detect and channel select setup as default and they are terrible at actually doing it
This guide https://www.plus.net/help/broadband/getting-the-best-wifi-signal/ may point you in the right direction
15-01-2017 5:00 PM
You might be suffering from this issue (Windows 10 and TG582n) and if so the fix is given within the post here https://community.plus.net/t5/Tech-Help-Software-Hardware-etc/Windows-10-upgrade-connectivity-proble...
15-01-2017 6:22 PM
i have gone through different channels and the only one it seems to work on is one with other people on. it was on channel 11 with no others on and would not work.
15-01-2017 6:22 PM
thanks but it works fine when plugged into ethernet cable.
15-01-2017 9:24 PM
11 should work, 12-14 may not always work
Did you force the devices to look for available networks as well as waiting for them to discover the change of channel (my ancient laptop never finds moved channels without a good kick)
