wifi calling and radio streaming continually dropping out
- wifi calling and radio streaming continually dropp...
06-05-2019 6:04 PM
I moved to Plusnet directly from John Lewis when the latter put the price up after 12 months.
HOWEVER I did have 12 months of PERFECT wifi calling and radio streaming. Now that I have moved to Plusnet (presumably EXACTLY the same infrastructure) I am having constant wifi dropouts which renders wifi calling completely useless and VERY irritating radio live streaming with the constant 1 second rewinds - 20 in a hour sometimes.
Re: wifi calling and radio streaming continually dropping out
06-05-2019 7:37 PM
Do you have ADSL or FTTC fibre broadband service?
Are you witnessing these issues on a particular device, or multiple devices?
If you have fibre and you are suffering from wifi issues, I suggest splitting the 2.4 and 5 GHz wifi signals if you are using a Hub One to see if it helps in first instance.
https://community.plus.net/t5/My-Router/2-4ghz-and-or-5ghz-best-practice/td-p/1351950
