whats the ip address range on the Technicolor TG582n
crobertbailey
Hi i have a whs set up that i cant access since swapping over my routers, its ip address when i could access it was 192.168.0.10 on a virgin superhub.
Now with the above the default is 192.168.1.254 and i wondered what the range of addresses was (192.168.1.254 > 192.168.1.274) for example
RPMozley
Re: whats the ip address range on the Technicolor TG582n
The DHCP address range is from 192.168.1.64 to 192.168.1.252
192.168.1.1 > .63 is reserved for devices requiring a static local IP (probably, I would guess as it's not mentioned anywhere).
Oh and just for your information IP addresses only go as far as 255, 274 is not possible. Wink
That's RPM to you!!
crobertbailey
Thanks for that will give it a go tonight and see how i get on
