what W7 gadgets you using?
scootie
asbo's wondering if his missing out on any must have gadgets.
So far ive got coretemp, gpu monitor and for the ebay addict my gf is ive got the ebay toolbar
Fixes: 62
Re: what W7 gadgets you using?
I didn't think of adding coretemp and GPU monitor but it is a good idea - goes off to check if GPU monitor works on my 8800GT card  Grin
scootie
this ones the best gpu monitor but you need the riviatuner installed, wouldnt work with my low end card on this machine.
http://gallery.live.com/liveItemDetail.aspx?li=0ae2038e-03c6-4454-9729-1bfd6626cc4c
http://downloads.guru3d.com/RivaTuner-v2.24c-download-163.html
XP Pro
Ubuntu 9.10
scootie
time to place that old relative xp pro in the care home me thinks
*asbo leaves the room before the big debate starts  Smiley
VileReynard
Seasoned Pro
Fixes: 10
Ubuntu 9.10
thisoldman
asbo plz get a copy of this weeks webuser mag they have a feature on the subject
Denzil
I'm using:
Wired Network Meter - handy graph of network (not just internet) incoming and outgoing speed.
All CPU Meter - to keep an eye on what the four cores( Cool) and the memory are doing.
Drive Activity - shows hard drive activity, funnily enough
Vista Calculator - MOD - because it's handy
Still exclusively using Linux Mint at home, though.
Steve
Seasoned Pro
Im using the all CPU meter and the weather gadget's.
If life gives you lemons, make lemonade.
bakerbloke
My Windows Media Center records or downloads my favourite freeview programs at night which are then (automatically) re-encoded and transferred to my iPod for the next morning by a recently discovered utility called iPodifier. A brief description can be found here:
http://silenceisdefeat.com/~rwightman/PVRprojects/Blog/Entries/2010/5/4_Want_to_have_your_recorded_T...
