website connection
- website connection
website connection
2 weeks ago
Re: website connection
2 weeks ago
@embee Welcome to the forums. I'm not 100% this is the right answer as your question is a little unclear, but assuming you are connecting wirelessly, are you sure the wireless adapter on the second machine is turned on/functioning correctly?
Can you connect the second machine to the router via a network cable and see if it works?
2 weeks ago - last edited 2 weeks ago
For a short period disable password security on router; try connection again.
If it works, something amiss on unconnectable PC's security settings. Re enable router security;
try again.
Also ensure the router SSID for the 2 frequencies are DIFFERENT eg add "5" at end of SSID
for 5ghz one.
