webmail
- webmail
- « Previous
- Next »
Re: webmail
05-11-2009 6:59 PM
hi SparckZero
cheers m8 the help is much appreciated
cheers binzy
cheers binzy
Re: webmail
06-11-2009 11:54 AM
Quote from: binzy hi bob
i have included the info you requested but cant for the life of me see how outlook express is going to make my emails viewable in my webmail prior to downloading it
Thanks, I've just responded to your ticket. Hopefully everything's sorted now?
Re: webmail
06-11-2009 12:11 PM
hi bob
thanks for what you have done already but please look in my emails as i bet there are others there because if my suspisions are right i will get internal mail from you displayed in my default webmail so before i download anything using outlook as i have not touched it this morning please check in my plusnet email accounts and see if there is other emails in there that are not from you because only your stuff is up on webmail no outside stuff
cheers binzy
cheers binzy
Re: webmail
06-11-2009 1:17 PM
hi bob
just had an email from ebay so must be ok will test further and post back later but thanks to all who responded here its much appreciated for all your help
cheers binzy
cheers binzy
- « Previous
- Next »
