webcams
Teds31
webcams
Sorry if this is in the wrong place,but when I try to get on to the PN webcams it says AxisActive X camera control could not be registered on your computer, can anyone say why as I used to have this on my old computer which ran XP.
1 REPLY
jnwright
Re: webcams
Others have had the same problem - see the thread at http://community.plus.net/forum/index.php/topic,1119.0.html
You'll find everyone points to downloading and installing the AXIS ActiveX Camera Control file to be found at http://www.tutorialsteam.plus.com/axiscameracontrol/AXISCameraServerControl.exe
The Webcams should display then.
Good luck!
