web counters on plusnet
davidstreatfiel
Hi All
I am in the process of putting a webcounter on my website I have found some code to do this but it says that it must be referenced to a URL  which is given but how do Reference the homepages URL to the counter code ?
Can anyone help me?
Thanks Dave
Tyreal74
Re: web counters on plusnet
Its usually your domain, i.e www.example.com
the code to put in is
<p  >
<img src="http://homepages.plus.net/cgi-bin/counter?username_pn"> </p>
Change username to yours same name as login into the portal
pierre_pierre
didnt quite work
It should be
<img src=
"http://homepages.plus.net/cgi-bin/counter?davidstreatfield_pn">
all on one line didnt notice it puts a counter in the forum if I put it on one line. If you put this as one line in the forum you get I assume your username is davidstreatfield
<img src="http://homepages.plus.net/cgi-bin/counter?davidstreatfield_pn">
pierre_pierre
Samuria the command to do what you was trying to achieve is [nobbc]
Edited name
Fixes: 117
Quote from: pierre_pierre
Jim the command.....
pierre the name you were looking for was Jan :p Wink Smiley
Will Moderate For Thanks
pierre_pierre
