vista display prob
- vista display prob
- « Previous
- 1
- 2
- Next »
Re: vista display prob
25-11-2007 10:59 PM
which is exactly what i was getting at - re-read my post m8
The feature is the ability to have your own set resolution as a different user. I'm sure microsoft intended that as a feature NOT a bug.
Care to correct me further or do you want to take me up on that re-read?
26-11-2007 12:23 PM
My apologies - I wasn't contradicting anything you said about screen resolutions.
However, the way in which Windows does this is is a bit rubbish (ie not designed and certainly not a feature). Windows shouldn't be showing any icons or anything until after it has set the resolution. The screen shouldn't be flashing at the user.
26-11-2007 5:42 PM
hi all. if this was a sreen res detecting at sart up.
why did this not start un till about 4 to 5 months after i bought the laptop. surely this prob would b from the begining.
r u shaw its not a driver prob as windows update did install a new driver some way back to do with my chipset family.
as said before i stoped every thing from starting up but did not solve prob.
its not a big problem but would b nice to find a soultion.
thanks 4 the repiles
02-12-2007 4:02 PM
Quote from: petlew Bill Gates....take what he says, divide by two, square the sum of that, subtract 95%
The answer is 16617.6125
A bit more than I expected
- « Previous
- 1
- 2
- Next »
