vista and office 2003
- vista and office 2003
01-08-2007 9:40 AM
any reason why office 2003 will not load on vista home edition, or do I have to buy office 2007 as well?
4 REPLIES 4
Re: vista and office 2003
01-08-2007 9:47 AM
It should work fine, what error message are you getting?
02-08-2007 6:40 PM
iam using office 2003 with no probs!
02-08-2007 7:36 PM
Is the problem with the install or after when you try and run the apps.
Make sure you have all the latest vista updates!
09-08-2007 10:08 AM
to be honest you can get 2003 working, with it's SP2 and about 16 updates after that, but to be honest, Office 2007 is the version designed to work with Vista.
also depends on what version of Vista you are running, any 64bit versions and 32bit Office 2003 isn't going to work.
