usb wireless adapter
craig_p
hi
i have got a spedtouch wireless router and was looking for a usb wireless adaptor for it to connect my laptop to it.  i have all my other units hard wired so would appriciate any advise
thanks
3 REPLIES 3
Re: usb wireless adapter
I've bought the cheapest own-brand stuff from Dabs and it's been fine. Had several of their wireless USB units.
Also used Netgear which is equally good.
The Dabs stuff doesn't suffer from over-complex management software, just load the drivers, turn off it's own management/configuration tools and use Windows.  Smiley
craig_p
thanks for the reply.  ive now borrowed a belkin usb stick and got the wireless network connection running ok.  when i try to set up the WEP key from the router, it tells me that it needs a 40 bit encription code where as the router only uses 64 or 128 bit.  could this be caused by XP not having the correct updates?  any ideas
craig
notheruser
Craig - you really should use WPA rather than WEP, as WEP is not considered secure.
