usb files
trufflesdad
usb files
Can anyone recommend a portable player that will play music from a usb device ?
4 REPLIES 4
shutter
Fixes: 64
Re: usb files
1. What physical size are you thinking about
2. Do you just want to play Audio
3 .Do you want to play Video Music files?
4. Does it have to be "dedicated" to being just a "player" or do you want something like a mobile phone with internet access?  ( small tablet ? )
This is what I have... and it does all the above !..
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=261462421183
From a USB stick, or from a TF card.
trufflesdad
Re: usb files
Thanks for the reply..All I need is a basic musicplayer that will play my mp3 usb sticks...
WTF
Re: usb files
You might be able to use your phone.
Quite a few recent droids now support OTG (USB On-The-Go) which means you just need an adaptor cable (has to be one that supports OTG but apparently you can get them for like £1) with a micro-USB end to plug in your phone and a USB end to plug your stick in.
See this article for more info - it talks about the HTC One but the info applies to any phone with OTG support (e.g. Nexus 5, Samsung S4 etc).
shutter
Fixes: 64
Re: usb files
Just make sure that the "micro" end is the same size as your phone !
