usage and speed
- usage and speed
usage and speed
22-07-2009 8:59 PM
i am new to broadband
can you get software to show speed and the amount of downloads
thanks john
thanks john
3 REPLIES 3
Re: usage and speed
22-07-2009 9:19 PM
Welcome to the forums and broadband
You can see your usage in the member centre.
http://www.mybroadbandspeed.com will show you your speeds
and you can also use something like this http://www.thinkbroadband.com/tbbmeter.html for realtime monitoring
Re: usage and speed
22-07-2009 10:40 PM
and for windows an on screen display Netmeter http://www.softpedia.com/progDownload/NetMeter-Download-23932.html its free
a frequently asked question, your allowance is the total of up and download traffic
Re: usage and speed
23-07-2009 10:42 AM
You can also view your usage with us by going to this page:
https://portal.plus.net/view_my_broadband_usage/index.php
