usage and speed
jablake
usage and speed
i am new to broadband
can you get software to show speed and the amount of downloads
thanks john
Fixes: 126
Re: usage and speed
Welcome to the forums and broadband Smiley
You can see your usage in the member centre.
http://www.mybroadbandspeed.com will show you your speeds
and you can also use something like this http://www.thinkbroadband.com/tbbmeter.html for realtime monitoring
Will Moderate For Thanks
pierre_pierre
Re: usage and speed
and for windows an on screen display Netmeter http://www.softpedia.com/progDownload/NetMeter-Download-23932.html its free
a frequently asked question, your allowance is the total of up and download traffic
James
Re: usage and speed
You can also view your usage with us by going to this page:
https://portal.plus.net/view_my_broadband_usage/index.php
