updating DRM without a sound card
- Re: updating DRM without a sound card
10-07-2012 2:29 PM
Hi All,
when trying to add digital copies of movies to my server it keeps trying to update the DRM, it gets so far then fails due to no sound card. is there a way round this does anyone know, if not i'l just burn a copy of the dvd instead, just thought i would use the digital copies since i havce them.
2 REPLIES 2
12-07-2012 8:45 PM
I have no idea whether this would work, but have you tried remoting into the server and running the software - you should get a virtual RDP sound driver in that case.
(although even if it does work, it can be somewhat of a hassle getting audio over RDP working on Windows Server)
12-07-2012 10:57 PM
thanks CX, i'l give that a go tomorrow
