update kb951847
- Re: update kb951847
update kb951847
18-09-2009 1:04 PM
it took ages to download when i closed down and it seems to have slowed down the pc when starting up.
has anyone had any trouble likewise and do i need this update ?
it does say i may uninstall.
do not currently fancy service pack 3 as some seem to have a load of trouble with it.
thankyou
Re: update kb951847
18-09-2009 1:09 PM
Maurice
Re: update kb951847
18-09-2009 1:16 PM
Re: update kb951847
18-09-2009 1:24 PM
was in trouble for a minute. the " c " stuck down.
well am dithering about 3 pack .
1 son won't download either. will have big think. may take the plunge.
however , shall i get rid of this update do you think???
the printoff says " .net framework 3.5 service pack 1 family update for net versions 2.0 through 3.5.
does the net version relate to s/p 2. thankyou
thanks too to >>> adiewoo. hope i don't have to come screaming for help.
Re: update kb951847
20-09-2009 6:14 PM
There was a lot of hype around the use of SP3 particularly from corporate IT depts. with a large userbase to support. As far as I am aware, this is now all in the past.
Maurice
Re: update kb951847
21-09-2009 4:19 PM
thankyou for clarifying the info on that download.
i think that i will delete.and then get the sce pack 3.
wish that i understood a bit more . thanks again.
Re: update kb951847
22-09-2009 1:12 PM
As others have said, you should be fine with SP3.
