unwanted taskbars
- unwanted taskbars
unwanted taskbars
11-05-2009 3:57 PM
I run firefox. I have downloaded upgrades for AVG & C CLEANER. Unfortunately I must have missed unticking the boxes and now I have unwanted taskbars from these products. Could you experts please inform me how to get rid of these taskbars.
Many thanks in anticipation.
TIMBERWOODY
TIMBERWOODY
5 REPLIES 5
Re: unwanted taskbars
11-05-2009 6:27 PM
Click on Tools - Add ons and the uninstall button for the task bar in question. Alternatively you may need to go the uninstall programmes window in Windows.
11-05-2009 6:34 PM
If you are using Internet Explorer just click on View, then move the cursor down to Toolbars and uncheck the ones you don't want to see - this is with IE8
11-05-2009 10:45 PM
Quote from: timberwoody I run firefox. I have downloaded upgrades for AVG & C CLEANER. ...
TIMBERWOODY
12-05-2009 8:09 AM
AVG has a web scanner, this used to be a terrible waste of band width, said to be much better now, go to the AVG control panel and you can turn that off from there
what other features are there that you dont like?, some you can click to off in the VIEW on the top line of Firefox
13-05-2009 10:47 PM
Job completed. many thanks john (HULLS)
Timberwoody
Timberwoody
