unlocking my bt voyager 210
onedart
Hello, I have been trying to unlock my bt voyager 210 router for any ISP. Any advice appreciated. Thanks
7 REPLIES 7
HPsauce
Re: unlocking my bt voyager 210
Didn't know they ever were locked. Where did you get it?
onedart
Xcatreturns. I didn't know either  :D. Apparently it's fairly straightforward to upgrade the firmware but I need to know if there is a way I can unlock it via my plusnet connection or do I need to find someone with bt broadband?
HPsauce
What is locked?
onedart
The voyager 210 router I bought is locked to BT broadband.
HPsauce
Can you be more specific?
Have you logged on to it as admin?
Peter_Vaughan
onedart
The internet connection configuration needed some tweaking, but it did work eventually.
Thanks a lot.
For reference (after you have upgraded firmware):
Select [Advanced] from the left menu
Select [Advanced] link at middle
Click [Internet] from the left menu
Click [Edit] (Pencil Icon) on right side
If not already set VPI number to 0
If not already set VCI number to 38
Click [Next]
[Select] Protocol: PPP over ATM (PPPoA): Encapsulation Type: VC MUX
Click [Next] 3 times
Click [Apply]
Click [Finish]
Restart computer to complete.
cp:quote
