unique wireless problem
- Re: unique wireless problem
14-04-2009 6:22 PM
Any help in solving this mistery will be welcome
14-04-2009 9:22 PM
Your (excellent) router is innocent.
Have you tried using Firefox to play the game - IE is integrated with the Microsoft OS rather tightly.
Works fine in Firefox - on Linux (Wirelessly)
15-04-2009 12:19 AM
what does the java console log say?
seems very strange that it kills the wireless on the router for all pc's
just loaded the website in IE8 on vista premium running on the netgear usb wireless adapter to a dg834 v4 and runs fine.
java version as below.
15-04-2009 8:43 AM
15-04-2009 9:34 AM
Java Plug-in 1.6.0_13
Using JRE version 1.6.0_13 Java HotSpot(TM) Client VM
User home directory = C:\Users\Laura
c: clear console window
f: finalize objects on finalization queue
g: garbage collect
h: display this help message
l: dump classloader list
m: print memory usage
o: trigger logging
q: hide console
r: reload policy configuration
s: dump system and deployment properties
t: dump thread list
v: dump thread stack
x: clear classloader cache
0-5: set trace level to <n>
security: property package.access value sun.,com.sun.xml.internal.ws.,com.sun.xml.internal.bind.
security: property package.access new value sun.,com.sun.xml.internal.ws.,com.sun.xml.internal.bind.,com.sun.javaws
security: property package.access value sun.,com.sun.xml.internal.ws.,com.sun.xml.internal.bind.,com.sun.javaws
security: property package.access new value sun.,com.sun.xml.internal.ws.,com.sun.xml.internal.bind.,com.sun.javaws,com.sun.deploy
security: property package.access value sun.,com.sun.xml.internal.ws.,com.sun.xml.internal.bind.,com.sun.javaws,com.sun.deploy
security: property package.access new value sun.,com.sun.xml.internal.ws.,com.sun.xml.internal.bind.,com.sun.javaws,com.sun.deploy,com.sun.jnlp
security: property package.definition value null
security: property package.definition new value com.sun.javaws
security: property package.definition value com.sun.javaws
security: property package.definition new value com.sun.javaws,com.sun.deploy
security: property package.definition value com.sun.javaws,com.sun.deploy
security: property package.definition new value com.sun.javaws,com.sun.deploy,com.sun.jnlp
security: property package.access value sun.,com.sun.xml.internal.ws.,com.sun.xml.internal.bind.,com.sun.javaws,com.sun.deploy,com.sun.jnlp
security: property package.access new value sun.,com.sun.xml.internal.ws.,com.sun.xml.internal.bind.,com.sun.javaws,com.sun.deploy,com.sun.jnlp,org.mozilla.jss
security: property package.definition value com.sun.javaws,com.sun.deploy,com.sun.jnlp
security: property package.definition new value com.sun.javaws,com.sun.deploy,com.sun.jnlp,org.mozilla.jss
basic: Added progress listener: sun.plugin.util.GrayBoxPainter$GrayBoxProgressListener@56a499
network: Cache entry not found [url: http://b.whyville.net/nmed1239664956/nmed3.jar, version: null]
network: Connecting http://b.whyville.net/nmed1239664956/nmed3.jar with proxy=DIRECT
network: Connecting http://b.whyville.net:80/ with proxy=DIRECT
network: Connecting http://b.whyville.net/nmed1239664956/nmed3.jar with cookie "visitDur=1239783381%3b1239783381; siteMode=whyville; origin; promocode; waitID=5448756; uid=5448756:5041aa32cd9ae18037ead94996098cb3; age=1239783410:bce925f301808c68a98a9c8959008655; vist=206686507"
network: Downloading resource: http://b.whyville.net/nmed1239664956/nmed3.jar
Content-Length: 81,770
Content-Encoding: null
network: Wrote URL http://b.whyville.net/nmed1239664956/nmed3.jar to File C:\Users\Laura\AppData\LocalLow\Sun\Java\Deployment\cache\6.0\48\62434b70-29ed9acf-temp
network: CleanupThread used 123682 us
network: CleanupThread used 4 us
network: No certificate info for unsigned JAR file: http://b.whyville.net/nmed1239664956/nmed3.jar
basic: Applet loaded.
basic: Applet resized and added to parent container
basic: PERF: AppletExecutionRunnable - applet.init() BEGIN ; jvmLaunch dt 582356 us, pluginInit dt 6461757 us, TotalTime: 7044113 us
nmed version 505
Loaded image: http://b.whyville.net/top/whysquarespring.gif
Warning: undefined variable returning default
Loaded image: http://b.whyville.net/smmk/face/img?uid=5292024&scale=2
Loaded image: http://b.whyville.net/newbieIsland/images/btnRestartOVER.gif
Loaded image: http://b.whyville.net/newbieIsland/images/btnRestartDOWN.gif
Loaded image: http://b.whyville.net/kajeet/imFlash0.gif
Loaded image: http://b.whyville.net/kajeet/imFlash1.gif
network: Cache entry not found [url: http://b.whyville.net/kajeet/imFlash1.gif, version: null]
network: Connecting http://b.whyville.net/kajeet/imFlash1.gif with proxy=DIRECT
network: Cache entry not found [url: http://b.whyville.net/smmk/face/img?uid=5292024&scale=2, version: null]
network: Connecting http://b.whyville.net/smmk/face/img?uid=5292024&scale=2 with proxy=DIRECT
basic: Applet initialized
basic: Removed progress listener: sun.plugin.util.GrayBoxPainter$GrayBoxProgressListener@56a499
basic: Applet made visible
basic: Starting applet
network: Cache entry not found [url: http://b.whyville.net/top/whysquarespring.gif, version: null]
network: Connecting http://b.whyville.net/top/whysquarespring.gif with proxy=DIRECT
network: Cache entry not found [url: http://b.whyville.net/kajeet/imFlash0.gif, version: null]
network: Connecting http://b.whyville.net/kajeet/imFlash0.gif with proxy=DIRECT
trying port: 443
network: Connecting http://b.whyville.net:443/ with proxy=DIRECT
network: Connecting http://b.whyville.net/kajeet/imFlash1.gif with cookie "visitDur=1239783381%3b1239783381; siteMode=whyville; origin; promocode; waitID=5448756; uid=5448756:5041aa32cd9ae18037ead94996098cb3; age=1239783410:bce925f301808c68a98a9c8959008655; vist=206686507"
network: Connecting http://b.whyville.net/smmk/face/img?uid=5292024&scale=2 with cookie "visitDur=1239783381%3b1239783381; siteMode=whyville; origin; promocode; waitID=5448756; uid=5448756:5041aa32cd9ae18037ead94996098cb3; age=1239783410:bce925f301808c68a98a9c8959008655; vist=206686507"
network: Connecting http://b.whyville.net/top/whysquarespring.gif with cookie "visitDur=1239783381%3b1239783381; siteMode=whyville; origin; promocode; waitID=5448756; uid=5448756:5041aa32cd9ae18037ead94996098cb3; age=1239783410:bce925f301808c68a98a9c8959008655; vist=206686507"
network: Connecting http://b.whyville.net/kajeet/imFlash0.gif with cookie "visitDur=1239783381%3b1239783381; siteMode=whyville; origin; promocode; waitID=5448756; uid=5448756:5041aa32cd9ae18037ead94996098cb3; age=1239783410:bce925f301808c68a98a9c8959008655; vist=206686507"
basic: Applet started
basic: Told clients applet is started
network: Cache entry not found [url: http://b.whyville.net/newbieIsland/images/btnRestartDOWN.gif, version: null]
network: Connecting http://b.whyville.net/newbieIsland/images/btnRestartDOWN.gif with proxy=DIRECT
network: Connecting http://b.whyville.net/newbieIsland/images/btnRestartDOWN.gif with cookie "visitDur=1239783381%3b1239783381; siteMode=whyville; origin; promocode; waitID=5448756; uid=5448756:5041aa32cd9ae18037ead94996098cb3; age=1239783410:bce925f301808c68a98a9c8959008655; vist=206686507"
network: CleanupThread used 5 us
network: Downloading resource: http://b.whyville.net/kajeet/imFlash0.gif
Content-Length: 313
network: Wrote URL http://b.whyville.net/kajeet/imFlash0.gif to File C:\Users\Laura\AppData\LocalLow\Sun\Java\Deployment\cache\6.0\4\113d1304-324a360d-temp
network: Cache entry not found [url: http://b.whyville.net/newbieIsland/images/btnRestartOVER.gif, version: null]
network: Connecting http://b.whyville.net/newbieIsland/images/btnRestartOVER.gif with proxy=DIRECT
network: Server http://b.whyville.net/smmk/face/img?uid=5292024&scale=2 requesting to set-cookie with "visitDur=1239783421%3b1239783421;Path=/;Domain=.whyville.net"
network: Downloading resource: http://b.whyville.net/newbieIsland/images/btnRestartDOWN.gif
Content-Length: 1,031
network: Wrote URL http://b.whyville.net/newbieIsland/images/btnRestartDOWN.gif to File C:\Users\Laura\AppData\LocalLow\Sun\Java\Deployment\cache\6.0\45\362ce76d-2dd34d48-temp
network: Connecting http://b.whyville.net/newbieIsland/images/btnRestartOVER.gif with cookie "visitDur=1239783421%3b1239783421; siteMode=whyville; origin; promocode; waitID=5448756; uid=5448756:5041aa32cd9ae18037ead94996098cb3; age=1239783410:bce925f301808c68a98a9c8959008655; vist=206686507"
network: Downloading resource: http://b.whyville.net/newbieIsland/images/btnRestartOVER.gif
network: Wrote URL http://b.whyville.net/newbieIsland/images/btnRestartOVER.gif to File C:\Users\Laura\AppData\LocalLow\Sun\Java\Deployment\cache\6.0\52\7eeac0b4-599a9ff0-temp
java.net.SocketTimeoutException: Read timed out
at java.net.SocketInputStream.socketRead0(Native Method)
at java.net.SocketInputStream.read(Unknown Source)
at java.io.DataInputStream.readFully(Unknown Source)
at net.whyville.applets.nmed.m.a(Unknown Source)
at net.whyville.applets.nmed.g.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
basic: unique id: com_sun_deploy_AboutJava-6.0
basic: server port at: 49299
basic: getSingleInstanceFilename: C:\Users\Laura\AppData\LocalLow\Sun\Java\Deployment\tmp\si\com_sun_deploy_AboutJava-6.0-x86_49299
basic: waiting connection
network: Connecting http://127.0.0.1:49299/ with proxy=DIRECT
basic: recv: javaws.singleinstance.stop
basic: removed SingleInstanceFile: C:\Users\Laura\AppData\LocalLow\Sun\Java\Deployment\tmp\si\com_sun_deploy_AboutJava-6.0-x86_49299
15-04-2009 3:55 PM
15-04-2009 5:19 PM
15-04-2009 5:27 PM
15-04-2009 10:09 PM
15-04-2009 10:23 PM
This allows you to capture all packets transmitted for later analysis - but is it worth it?
15-04-2009 10:45 PM
16-04-2009 2:04 AM
you can google to find out what the packets are and are doing or you can upload your wireshark capture file or take a screen shot of wireshark and we can have a see whats going on. it may not help solve the problem but wiresharks solved alot things for me in the past.
to download http://www.wireshark.org/ and plusnet help pages on using wireshark http://www.plus.net/support/broadband/troubleshooting/wireshark.shtml
16-04-2009 1:59 PM
08-07-2009 9:57 AM
Also, am I right in thinking that it is only when she loads this site on one of your computers?
Might be unconnected, but I disabled uPnP on my router last year after some weirdness occuring whereby my Windows XP would think the router wasn't connected to the net and try to connect it, but in reality it was the other way round and it was forcing a disconnect! This usually happened when my OH at the time would be online with her Mac, and then I turned my Win XP laptop on. As I say, potentially very much a different issue, but maybe worth exploring?
James
08-07-2009 1:28 PM
If you have a router which has power you can do admin via wifi or ethernet connection - a telephone connection is optional for this.
Why not block that whyville site - either on the PC or in the router?
