trying to setup wifi on my iphone
suedname
Hi guys,What title do i give to set up  to wi-fi on iphone? phone has a list of networks to choose from,my router is netgear which is listed but it wont accept my password any ideas?
cheers
1 REPLY
Fixes: 62
Re: trying to setup wifi on my iphone
Which password
Assuming you are using  WPA-PSK Security Encryption then it is the network key you set up during the initial set up of the router
