transfer broadband to new computer?
ajay
Hi I am thinking of getting a new computer and I know this is a dumb question but how do I transfer the broadband to my new computer I still have the set up disc from when I connected to plusnet in 05 do I just load this?? thanks ajay
13 REPLIES 13
VileReynard
Fixes: 20
Re: transfer broadband to new computer?
There is no set-up disk.
HPsauce
Could be if it's a USB modem.
What make & model is the box that connects your PC to the filter in the phone socket?
mal0z
Maybe add a new router then, USB modems are inferior to a connections directly into the PC's Ethernet port which is on the vast majority of new PC's if not all.
- then as Taxi... says - you just plug the Ethernet cable from PC to router, and run the Windows network set up .
Oldjim
Resting Legend
Fixes: 63
Two things.
If you intend to stay with Plusnet you could get a router for the cost of the postage
A new computer will come with Windows 7 and it will find the router automatically and I think that the Plusnet router is preconfigured and will automatically connect
Strat
Fixes: 565
@ajay It's not a dumb question. Smiley
If you don't know, you ask and in here's one of the best places to do so Smiley
mal0z
Quote from: Oldjim
Yes - they do have this easy set up feature
http://community.plus.net/blog/2009/08/06/router-setup-the-easy-way/
Some of us here were part of the trials before it went live - it works well .
VileReynard
Fixes: 20
It doesn't need a special pre-configuration.
Routers include a friendly web interface for configuration purposes (a router contains its own processor and memory etc).
It also contains a firewall, to help protect PC's with flabby security. Cheesy
ReedRichards
Seasoned Pro
Fixes: 25
Ajay, not to beat about the bush:
If you have a router then no set-up is required - just connect a cable from your router to the new computer
If you have a modem (or any other device that uses a USB connector) then you are faced with some difficulty.  A disk supplied in 2005 will not have suitable USB drivers for a new computer.
If you don't know whether it's a modem or a router post whatever part number it has and we will tell you.
ajay
Thanks for all the help, I have raised a the question with tech support and my old router is not compatible with windows 7 so , I am waiting for a new router, hope it comes soon as the new computer is raring to go !! ajay
VileReynard
Fixes: 20
Then it wasn't a router.
It was some bit of cheap USB junk. Cheesy
ajay
router was supplied by plusnet in 2005 Huh hope the new one they supply  wont be judged as badly ?? ajay
HPsauce
Technology moves on apace. Broadband 4 or 5 years ago was very different to now.
It almost certainly isn't actually a router as modern PC's will talk happily to almost any router.
It's more likely to be an ADSL modem with a USB connection to the PC.
In January 2005 I was still on a fixed 512kbps ADSL connection with a USB device, now I'm running a Netgear router on a 21mbps ADSL2+ line. 40 times faster downloads!
VileReynard
Fixes: 20
I had broadband (512 kbps) Cheesy in 2001 Smiley
This was before I'd ever heard of USB - I had a 1 port (ethernet) router.
