thunderbird sunc with an Ipaq
hulls
Hi
As you may have seen from another thread, I've just started using Thunderbird instead of Outlook as my email client.  Is there a way to get my HP Ipaq to sync with Thunderbird rather than Outlook?  Huh
2 REPLIES 2
Fixes: 1,483
Re: thunderbird sunc with an Ipaq
Hi John,
Take a look at http://smartsync.mozdev.org/default.htm
hulls
Looks perfect, but it won't install.  It says it's only compatible with versions 1.2 to 2.0 of Thunderbird.  I'm using version 2.0.0.18  Crazy
