thompson wireless router
- thompson wireless router
07-02-2010 11:54 AM
hi i am new to plusnet and not very tech mineded ! so can anyone tell me why on my laptop the connection icon at the bottom of page indicates i am on - plusnet but on my desktop it says network 3 public access ( OR SOMTHING LIKE THAT) is this normal and safe as both using same router although desktop is using the earthnet cable. would appreciate help in understanding this. thanks
1 REPLY 1
Re: thompson wireless router
08-02-2010 10:46 AM
Have a look at control Panel> network connections for the desktop, see if 3 network is shown as this is the one it is using.
You can r/click and rename it to plusnet.
There can be other connections in there for dialup/mobile broadband/ethernet cable/ wireless card, according to what has been used in the past.
