thinkbroadband Broadband Quality Meter - dynamic IP
jelv
Fixes: 10
You no longer need to be on a static IP to use the thinkbroadband Broadband Quality Meter.
You may provide a hostname, IPv4 or IPv6 address to monitor.
https://www.thinkbroadband.com/broadband/monitoring/quality/create
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
7 REPLIES 7
30FTTC06
Fixes: 4
Re: thinkbroadband Broadband Quality Meter - dynamic IP
Tell that to these folk https://community.plus.net/t5/custom/page/page-id/_PingGraphs
Can't see your post either...
jaread83
Fixes: 81
Looks like the TBB website update has broken the ping graphs page that @bobpullen maintains! I have just messaged him about it.
30FTTC06
Fixes: 4
jelv
Fixes: 10
There is a problem with the old links but newly created ones are fine.
This was set up this morning using the host name for my connection:
My Broadband Ping - AAISP FTTC IPv4
bobpullen
Fixes: 314
Since been fixed.
St3
Aspiring Champion
Fixes: 5
I see they updated their website Smiley
Mayfly
All Star
Am I correct in thinking the Sagecom 2704N isn't supported?
