tbbMeter Trial - window size
radiobod
I have just installed tbbMeter as part of the Plusnet broadband speed trial.  The main display window (thinkbroadband) is fine, but any other window I try to display is too small and only displays part of the window content.  I am unable to increase the size of the window or to move within it and am therefore unable to register the software or to provide the Instance Number.  Any ideas, anyone?
perfectday
Re: tbbMeter Trial - window size
click on 'menu' bottom right - then 'ttbinformation' - you will then see the instance number.
jim:quote
pierre_pierre
Welcome to you lot from TBB, thats three today
Just one point dont quote in full the preceeding thread, its a gin this forum rules and will get removed
Fixes: 8
Why are we suddenly getting people asking questions about the crappy tbbMeter?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
matt_2k34
Check your emails Jelv?
Looksy here?
Matt
pierre_pierre
Dont know how you found that, I havnt had any Plusnet e-mails about it, and it is supposed to be in the Plusnet News section and dated 18th Feb, but if you go to that in the RH menu, no mention of it
Yet another PN secrect three monthe free?
Fixes: 57
They only started coming out yesterday evening or late afternoon - I received mine at 17:31
radiobod
This is seriously crappy software.  If I click on Menu (or right click into the main tbb window) the menu displays for a fraction of a second then disappears.  If I persist long enough it occasionally stays long enough for me to select something, but the resulting window is only partially displayed.  Thanks, perfectday, I can just read the Instance Number as the information page cuts off just below it, but it will not allow me to copy it so that I may then paste it into the email back to Plusnet.  Also, I still can't display enough of the Register page to select Register and it won't even allow me to close it, it comes straight back again.  I feel like ditching the whole thing.
Picnic
I managed to register it ok and get my instance number which I've submitted but now everytime I click on tbbmeter's menu it goes busy and window's says it has stopped responding. I don't seem to be able to kill it with Task Manager either. I have to log off and back on or reboot to clear it  Roll eyes
Fixes: 57
You will probably need to kill a process or two not just the application
Picnic
That's what I had ended up doing but the [tt]ttbmeter.exe *32[/tt] never quits. The Window remains on screen with the classic bright view when an app becomes non responsive. It stops updating the graph when it goes wonky like this too and window's displays a busy cursor when the mouse is moved over it Sad Just checked, Task Manager's Application tab doesn't show ttbmeter in its list after it's died.
Fixes: 57
Look at processes for all users
Picnic
On already. I've just discovered 2 untruths. Logging off is not sufficient to clear the process, only a restart of Windows fixes it. Secondly it doesn't happen every time as I just managed to access the menu again straight after a reboot
pierre_pierre
hope you have a big data allowance, did you read the program description? see below
Fixes: 57
That won't be a problem as you will see if you ever get the email
