suspicious security alert, showing three or four times a week
- suspicious security alert, showing three or four t...
- « Previous
- 1
- 2
- Next »
Re: suspicious security alert, showing three or four times a week
24-09-2015 8:56 AM
Quote from: villagecanvases It turned up again this morning. All that is said on Task Manager was 'Google security notice' which wasn't very helpful. However, I have decided to change from Chrome browser to Commodo Dragon which is based on Chrome to see if that stops it. Apparently Commodo has additional security blocks, so, yet again, fingers crossed.
In chrome check addons section just incase its some kinda addon spyware, still sounds like spyware too me. If it was happening to me id uninstall chrome and make sure i remove any folders related too it and then reboot and re download chrome from googles offical site. I personally would not try anything else until i found the root of the problem.
Theres another program you can try ive not needed to use this in a while, it may help and its free Have a look at this http://sourceforge.net/projects/hjt/ it will scan your files you will need to look for the suspicious links you see highlight it and click on info see what comes up then try and fix it see what happens
Ive googled the support number that pops up and found some others who have had this, http://forums.windowscentral.com/windows-10/381347-error-message-browser-being-asked-call-number-hel...;
Its deffo spyware or virus of some kind, also give these a try http://housecall.trendmicro.com/uk/ you may also want to run your pc in safe mode and try running malwarebytes and your avg, i got rid of avg 12 months ago because it was getting full of adverts and theres a few in these forums done the same if your happy thats cool but you may like to try avast its what i use https://www.avast.com/en-gb/index its free all you need to do is register your e-mail.
I wouldnt give up and trying to find the root of this issue because it could get worse
24-09-2015 9:08 AM
24-09-2015 12:05 PM
24-09-2015 12:18 PM
24-09-2015 7:32 PM
Each threat removed will be listed on a separate line with the headings giving various details. Scrolling far right shows the virus name which might be of interest to readers.
David
24-09-2015 8:50 PM
24-09-2015 10:58 PM
David
25-09-2015 9:31 AM
30-09-2015 10:19 AM
02-10-2015 12:26 PM
02-10-2015 5:07 PM
- « Previous
- 1
- 2
- Next »
