surround sound
Brickinit
surround sound
built myself a media center and i am trying to figure out the best way to setup a surround sound system to go with it. can i just use the audio out put from the motherboard which is 5.1 or should i come of the back of the TV and then into an amp ect?
jmd
Re: surround sound
oh gosh, another serious thread - on a Saturday night too! Cheesy Grin Cheesy Grin
Fixes: 13
Re: surround sound
To use surround sound you need four speakers, one in each corner of the room, and look in your sound card settings to see if it supports surround sound..... I remember my W95  desktop did, and you had a test which simulated a helicopter  flying round your front room...........
Quote from: jmd
And I fell for it ............ hook, line, and soundcard  Grin  Grin
pierre_pierre
Re: surround sound
and dont forget the one for the young idiots that goes bump bump in the front middle Kiss
Dont think TV's give out 5.1 only DVD  (and Maybe HD)
Re: surround sound
If you want to go high end, get a soundcard with optical out and a surround sound amp with optical in (and a decent speaker set). If you're not too worried about spending loads, get a powered speaker set and just use 3.5mm jack -> phono leads to connect it up.
